Mandatory Oracle Solaris 10 OS Patches
If you choose to install the Oracle Solaris 10 OS, you must also install additional patches,
and in some cases, a patch bundle.
Oracle Solaris 10 1/13 Mandatory Patches
This version of the OS is supported in the control domain, guest domains, or for
nonvirtualized configurations:
1
Oracle Solaris 10 1/13 OS
2
Mandatory patches:
148322-07 (or higher)
148324-06 (or higher)
148888-03 (or higher)
149638-01 (or higher)
149644-01 (or higher)
150011-02 (or higher)
150025-01 (or higher)
150027-01 (or higher)
150107-01 (or higher)
Oracle Solaris 10 8/11 Mandatory Patches
This version of the OS is supported only in guest domains.
1
Oracle Solaris 10 8/11 OS
2
Oracle Solaris 10 1/13 SPARC Bundle
3
Note -
Until the Oracle Solaris 10 1/13 SPARC Bundle is installed, the Oracle Solaris 10 8/11 OS
supports only 512 CPUs and 3840 Gbytes of memory. For servers exceeding those resources, reduce the
resources until the Oracle Solaris 10 1/13 SPARC Bundle is installed, or install a later version of
the Oracle Solaris OS.
Note -
Until the Oracle Solaris 10 1/13 SPARC Bundle is installed, you might encounter these Oracle
Solaris bugs—15712380, 15704520, 15665037. The first two bugs are resolved when these Oracle
Solaris 10 1/13 SPARC bundle is installed. These bugs do not impact the patch installations.
Oracle Solaris 10 9/10 Mandatory Patches
1
Oracle Solaris 10 9/10 OS
2
3
Note -
Until the Oracle Solaris 10 1/13 SPARC Bundle is installed, the Oracle Solaris 10 9/10 OS
Note - Until the Oracle Solaris 10 1/13 SPARC Bundle is installed,
you might encounter bugs 15712380, 15704520, and 15665037. The first
two bugs are resolved when the Oracle Solaris 10 1/13 SPARC Bundle
