man pages section 3: Extended Library Functions, Volume 2
Exit Print View
Updated: July 2014
it_ini_setprop(3ISCSIT)
Name
it_ini_create, it_ini_setprop, it_ini_delete, it_ini_free - create, modify and delete iSCSI Initiator Contexts
Synopsis
cc [ flag… ] file… –liscsit [ library… ]
#include <libiscsit.h>
int it_ini_create(it_config_t *cfg, it_ini_t **ini,
     char *ini_node_name);
int it_ini_setprop(it_ini_t *ini, nvlist_t *proplist,
     nvlist_t **errlist););
void it_ini_delete(it_config_t *cfg, it_ini_t *ini);
void it_ini_free(it_ini_t *ini);
Parameters
cfg
a pointer t the iSCSI configuration structure
ini
a pointer to the it_ini_t structure representing the initiator context
ini_node_name
the iSCSI node name of the remote initiator
proplist
a pointer to an nvlist_t containing the initiator properties to be set
errlist
an optional pointer to an nvlist_t that will be used to store specific errors (if any) when validating initiator properties
Description
The it_ini_create() function adds an initiator context to the global configuration.
The it_ini_setprop() function validates the provided property list and sets the properties for the specified initiator. If errlist is not NULL, this function returns detailed errors for each property that failed. The format for errlist is key = property, value = error string.
The it_ini_delete() function removes the specified initiator context from the global configuration.
The it_ini_free() function deallocates resources of an it_ini_t structure. If ini→next is not NULL, this function frees all members of the list.
Configuration changes as a result of these functions are not instantiated until the modified configuration is committed by calling it_config_commit(3ISCSIT).
Initiator nvlist properties are as follows:
nvlist Key
Type
Valid Values
chapuser
string
any string, or none to remove
chapsecret
string
string of at least 12 characters but not more than 255 characters. secret will be base64 encoded when stored.
Return Values
The it_ini_create(), it_ini_setprop(), and it_ini_delete() functions return 0 on success and an error value on failure.
Errors
The it_ini_create(), it_ini_setprop(), and it_ini_delete() functions will fail if:
EEXIST
The requested initiator context is already configured.
EINVAL
A parameter or property is invalid.
ENOMEM
Resources could not be allocated.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
it_config_commit(3ISCSIT), it_portal_create(3ISCSIT), it_tgt_create(3ISCSIT), it_tpg_create(3ISCSIT), libiscsit(3LIB), libnvpair (3LIB), libstmf(3LIB), stmfGetProviderData(3STMF), stmfSetProviderData(3STMF), attributes(5)
