man pages section 3: Extended Library Functions, Volume 2
Exit Print View
Updated: July 2014
it_tgt_setprop(3ISCSIT)
Name
it_tgt_create, it_tgt_setprop, it_tgt_delete, it_tpgt_create, it_tpgt_delete, it_tgt_free, it_tpgt_free - create, modify and delete iSCSI Targets
Synopsis
cc [ flag… ] file… –liscsit [ library… ]
#include <libiscsit.h>
int it_tgt_create(it_config_t **cfg, it_tgt_t **tgt,
     char *tgt_name);
int it_tgt_setprop(it_config_t *cfg it_tgt_t *tgt,
     nvlist_t *proplist, nvlist_t **errlist);
int it_tgt_delete(it_config_t *cfg, it_tgt_t *tgt,
     boolean_t force);
int it_tpgt_create(it_config_t *cfg, it_tgt_t *tgt,
     it_tpgt_t **tpgt, char *tpg_name, uint16_t tpgt_tag);
void it_tpgt_delete(it_config_t *cfg, it_tgt_t *tgt,
     it_tpgt_t *tpgt);
void it_tgt_free(it_tgt_t *tgt);
void it_tpgt_free(it_tpgt_t *tpgt);
Parameters
cfg
a pointer to the iSCSI configuration structure
tgt
a pointer to an iSCSI target structure
tgt_name
the target node name for the target to be created. The name must be in either IQN or EUI format. If this value is NULL, a node name will be generated automatically in IQN format.
proplist
a pointer to an nvlist_t containing the target properties to be set
errlist
an optional pointer to an nvlist_t that will be used to store specific errors (if any) when validating target properties
force
a boolean value indicating if the target should be set to offline before removing it from the configuration. If not specified, the operation will fail if the target is determined to be online
tpgt
a pointer to a target portal group tag structure
tpgt_name
the name of the target portal group to be associated with this target portal group tag
tpgt_tag
a 16-bit numerical identifier for this target portal group tag. Valid values are 2 through 65535. If tpgt_tag is '0', it_tpgt_create() will assign an appropriate tag number. If tpgt_tag is != 0, and the requested tag number is unavailable, another value will be chosen.
Description
The it_tgt_create() function allocates and creates an it_tgt_t structure representing a new iSCSI target node. If tgt_name is NULL, then a unique target node name will be generated automatically. Otherwise, the value of tgt_name will be used as the target node name. The new it_tgt_t structure is added to the target list (cfg_tgt_list) in the configuration structure.
The it_tgt_setprop() function validates the provided property list and sets the properties for the specified target. If errlist is not NULL, this function returns detailed errors for each property that failed. The format for errlist is key = property, value = error string.
The it_tgt_delete() function removes the target represented by tgt from the configuration. The tgt argument is an existing it_tgt_t structure within the configuration cfg.
The it_tpgt_create() function allocates and creates an it_tpgt_t structure representing a new iSCSI target portal group tag. The new it_tpgt_t structure is added to the target tpgt list (tgt_tpgt_list ) in the it_tgt_t structure.
The it_tpgt_delete() function removes the target portal group tag represented by tpgt, from the configuration. The tpgt argument is an existing is_tpgt_t structure within the target tgt.
The it_tgt_free() function frees an it_tgt_t structure. If tgt→next is not NULL, this function frees all structures in the list.
The it_tpgt_free() function deallocates resources of an it_tpgt_t structure. If tpgt->next is not NULL, this function frees all members of the list.
Configuration changes as a result of these functions are not instantiated until the modified configuration is committed by calling it_config_commit(3ISCSIT).
Target nvlist properties are as follows:
nvlist Key
Type
Valid Values
targetchapuser
string
any string, or none to remove
targetchapsecret
string
string of at least 12 characters but not more than 255 characters. secret will be base64 encoded when stored.
alias
string
any string or none to remove
auth
string
radius, chap, or none
Return Values
The it_tgt_create(), it_tgt_setprop(), it_tgt_delete(), it_tpgt_create(), and it_tpgt_delete() functions return 0 on success and an error value on failure.
Errors
The it_tgt_create(), it_tgt_setprop(), it_tgt_delete(), it_tpgt_create(), and it_tpgt_delete() functions will fail if:
E2BIG
All tag numbers are already in use.
EBUSY
The target is online.
EEXIST
The requested target node name is already configured.
EINVAL
A parameter or property is invalid.
ENOMEM
Resources could not be allocated.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
it_config_commit(3ISCSIT), it_ini_create(3ISCSIT), it_portal_create(3ISCSIT), it_tpg_create(3ISCSIT), libiscsit(3LIB), libnvpair (3LIB), libstmf(3LIB), attributes(5)
