Supported OS Levels
The 6.0.0-ESX release of host drivers was tested with and supports the VMware ESXi 6.0 GA with
ESXi 6.0.0 build-2494585 version of VMware hypervisor.
Note - Update to the latest version of the operating system
and apply pertinent patches to help configure your server for ideal
performance.
Note -
You do not need a new driver for the minor patches or updates from VMware. The
existing driver does not break when you upgrade to latest patches or minor
updates. For example, if you have installed OVN-ESX-6.0.0 drivers on VMware
ESXi-6.0-GA build-2494585 and you get a latest patch or update from VMware with
fixes, then you can just apply the patch to your ESXi host and the existing
OVN-ESX-6.0.0 works for the minor update or patch without breaking.
