20978336 |
A physical uplink or vNIC/PVI-vNIC vanishes with
reboot
A physical link or vNIC/PVI-vNIC that is assigned to DV switch as uplink, will not be
available after ESXi-host reboot (VMware bug).
Workaround: Reassign physical link or vNIC/PVI-vNIC as
uplinks to the respective DV switch ports. |
18411379
Required VIB Is Not
Present
The net-ib-cm VIB is not present with ESXi
5.1 with version 5.3.1 of Oracle Virtual Networking host drivers for
ESXi hosts. As a result, esxcli-update operations
going from ESXi 5.0 releases to ESXi 5.1 or later will fail because
of the absence of the VIB in the older versions of host drivers.
Upgrading from ESXi 5.1 to another release equal to, or greater
than, ESXi 5.1 should not experience this problem.
Workaround: Use a remastered
ISO when updating to the latest version of host drivers.
18389464 |
Incorrect Stat
for vNICs That Have Been Configured, Deleted, and Re-added With
a New Name
Assume you have successfully created a PVI vNIC on a PVI Cloud.
If you then remove that PVI vNIC, rename it, and attempt to add
it back to the PVI cloud, the vNIC is put into up/fail state.
Workaround: Do either of the following:
Reboot the host server
after deleting the original PVI vNIC, then create the new PVI vNIC.
Reboot the host server after the PVI vNIC is adding
in up/fail state. After reboot, the PVI vNIC will be in up/up state.
16337075 |
When Multiple Virtual Connections
of the Same Type Use the Same Name, Only the First One Added Comes Online Properly
If you add vNICs and vHBAs with the same name to an ESXi host,
the first virtual I/O device comes up. When you add the second virtual
I/O device, it comes up in a failed state.
Workaround: Ensure that vNICs and vHBAs have unique
names. |
16336591 |
PowerPath Problem When
FibreChannel Frames Get Dropped
Consider the situation where EMC storage is directly connected to the Oracle Fabric
Interconnect and is available to an ESXi server running at least
version 5.1, and also running PowerPath. If FibreChannel frames get
dropped, the ESXi server might crash and display a pink screen of
death (PSOD). This issue originates in PowerPath code.
Workaround: No workaround
exists for this issue. |
16334716 |
Problem With Multipath
vHBAs and PowerPath
Consider the situation where an ESXi server is running at
least version 5.1, is connected to storage through multipath vHBAs,
and is running PowerPath 5.7. If you delete the active vHBA, the server
might crash and display a pink screen of death (PSOD).
Workaround: Reboot the server, then stop traffic on the
active vHBA that you want to delete by running the set
vhba
name
down command before deleting the active vHBA. |
