Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
VLAN Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
VLAN Configuration
Configuration Guidelines
Default Settings
Configuring Static VLAN Entries
Create Member Ports
Create Forbidden Ports
Viewing VLAN Information
Retrieve the VLAN Summary
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Delete a VLAN
Enable VLANs
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring QinQ
Enable Tunneling on a Port
Enable STP Packet Tunneling
Configure QinQ
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configuring Port Filtering
Configure the Acceptable Frame Type
Configure Ingress Filtering
Flow-Based Configuration
Flow-Based Example Topologies
Example Topolgy 1
Example Topolgy 2
Example Topolgy 3
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configuring GVRP
Configure VGRP for Topology 1
Configure VGRP for Topology 2
Configure VLANs on the Nonroot Bridge
Configure GMRP
Classify VLANs
Create Acceptable Frame Types
For this procedure, you must first configure the VLAN. See Example Topolgy 1 for the topology for this procedure.
  1. Configure the VLAN in switch 1.
    SEFOS# configure terminal
    SEFOS(config)# vlan 2
    SEFOS(config-vlan)# ports extreme-ethernet 0/3,0/15,0/19
    SEFOS(config-vlan)# exit
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
    SEFOS(config)# interface extreme-ethernet 0/15
    SEFOS(config)# interface extreme-ethernet 0/19
    SEFOS(config)# mac-address-table static unicast 00:1b:21:53:6e:55 vlan 2 interface ext 0/15
    SEFOS(config)# exit
  2. Review the VLAN-related configurations.
    SEFOS# show vlan id 2
    Vlan database
    Vlan ID             : 2
    Member Ports        : Ex0/15, Ex0/19
    Untagged Ports      : None
    Forbidden Ports     : None
    Name                :
    Status              : Permanent
  3. After the spanning tree topology settlement, send the tagged (VLAN 2) unicast data packet to host B from host A.
  4. Check the learned MAC addresses.
    SEFOS# show mac-address-table
    Vlan     Mac Address          Type       Ports
    2        00:1b:21:53:6d:b9    Learnt     Ex0/19
    2        00:1b:21:53:6e:55    Static     Ex0/15
    Total Mac Addresses Displayed: 2
