| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System VLAN Administration Guide |
Configuring Static VLAN Entries
Retrieve the Configuration Details for all of the VLANs on a Switch
Retrieve the Configuration Details of a particular VLAN on the Switch
Configure a Static Unicast Entry
Configure a Static Multicast Entry
Configure Dynamic VLAN Learning
Configure Dynamic Multicast Learning
Configure Restricted VLAN Registration
Configure Restricted Group Registration
Configuring Service Classes and Expedited Traffic
Map a Priority to Traffic Class
Configure the Acceptable Frame Type
Configuring Static Unicast and Multicast Entries
Configure Static Unicast Entry in Topology 1
Configure Static Unicast Entry in Topology 2
Configure VLANs on the Nonroot Bridge
To configure GMRP, you must ensure that the following prerequisites are met:
Interface P3 in switch 1 and switch 2 must be enabled.
Static multicast entry must be configured.
See Default Settings for the topology for this procedure.
SEFOS# configure terminal SEFOS(config)# interface range extreme-ethernet 0/3-4 SEFOS(config-if)# no shutdown SEFOS(config-if)# exit SEFOS(config)# vlan 2 SEFOS(config-vlan)# ports extreme-ethernet 0/3-4 SEFOS(config-vlan)# exit SEFOS(config)# mac-address-table static multicast 01:02:03:04:05:06 vlan 2 interface extreme-ethernet 0/3 SEFOS(config)# end
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# no shutdown SEFOS(config-if)# end
SEFOS# show mac-address-table static multicast Static Multicast Table ----------------------------- Vlan : 2 Mac Address : 01:02:03:04:05:06 Receive Port : Member Ports : Ex0/3 Status : Permanent ------------------------------------ Total Mac Addresses displayed: 1
SEFOS# show mac-address table Vlan Mac Address Type Ports ------- ------------------- ------- -------- 1 00:14:4f:6c:61:d1 Learnt Ex0/3 1 00:1b:21:53:71:f9 Learnt Ex0/3 2 00:14:4f:6c:61:d1 Learnt Ex0/3 2 01:02:03:04:05:06 Static Ex0/3 Total Mac Addresses displayed: 4
