| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System IPv6 Administration Guide |
Route Redistribution Topology in IPv6
Completing Preliminary Configurations
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configuring the Route Redistribution Topology
Configuring IPv6 Support in an Interface
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Static Routes
Configuring Static Neighbor Cache Entries
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Setting the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Redistribution Policy for Routing Protocols
SEFOS# configure terminal
SEFOS(config)# ipv6 path mtu 2004::0 1500
where:
2400::0 is the prefix address.
1500 is the MTU value.
SEFOS# ping ipv6 fec0::3333:0:10 size 1800 ping6 fec0::3333:0:10 1800 bytes of data 1800 bytes from fec0::3333:0:10 : icmp_seq = 0 1800 bytes from fec0::3333:0:10 : icmp_seq = 1 1800 bytes from fec0::3333:0:10 : icmp_seq = 2 1800 bytes from fec0::3333:0:10 : icmp_seq = 3 1800 bytes from fec0::3333:0:10 : icmp_seq = 4 --- Ping Statistics --- 5 Packets Transmitted, 5 Packets Received, 0% Packet Loss
SEFOS# show ipv6 pmtu PMTU discovery is enabled Ipv6 Path MTU Table ----------------- Destination PMTU ----------- ---- fec0::1111:0:01200
