Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System MLDS Administration Guide |
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
Enable Query Transmission on Topology Change
When MLDS is enabled globally, it is enabled in all the existing VLAN interfaces. When MLD snooping is disabled globally, it is disabled in all the existing VLAN interfaces. However, you can enable MLDS on specific VLANs, as described in the following example.
In this example, MLDS is enabled on VLAN 2.
SEFOS# configure terminal SEFOS(config)# vlan 2
SEFOS(config-vlan)# ipv6 mld snooping SEFOS(config-vlan)# end
SEFOS# show ipv6 mld snooping vlan 2 Snooping VLAN Configuration for the VLAN 2 MLD Snooping enabled MLD Operating version is V2 Fast leave is disabled Snooping switch is acting as Non-Querier Query interval is 125 seconds
When MLDS is globally enabled or disabled, but not enabled on VLAN 2, the second line in the output of this command is:
MLD Snooping disabled
