Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System MLDS Administration Guide |
Enable MLDS in a Specific VLAN
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
To display MLD statistics, follow the steps described in the following task.
SEFOS# show ipv6 mld snooping statistics Snooping Statistics for VLAN 1 General queries received: 0 Group specific queries received: 0 Group and source specific queries received: 0 ASM reports received: 3 SSM reports received: 0 IS_INCLUDE messages received: 0 IS_EXCLUDE messages received: 0 TO_INCLUDE messages received: 0 TO_EXCLUDE messages received: 0 ALLOW messages received: 0 Block messages received: 0 Done messages received: 0 General queries transmitted: 0 Group specific queries transmitted: 0 ASM reports transmitted: 0 SSM reports transmitted: 0 Done messages transmitted: 0 Packets dropped: 0
