Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System MLDS Administration Guide |
Enable MLDS in a Specific VLAN
Configure the Multicast Forwarding Mode
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
Enable Query Transmission on Topology Change
The snooping version for a specific VLAN can be configured as either v1 or v2. By default, the operating version of the MLDS switch for all the VLANs is v2. In this example, VLAN 4 is the VLAN for which the snooping version is to be configured, and the snooping version is 1.
SEFOS# configure terminal SEFOS(config)# vlan 4 SEFOS(config-vlan)# ipv6 mld snooping version v1 SEFOS(config-vlan)# end
SEFOS# show ipv6 mld snooping vlan 4 Snooping VLAN Configuration for the VLAN 4 MLD Snooping enabled MLD configured version is V1 Fast leave is disabled Snooping switch is configured as Non-Querier Snooping switch is acting as Non-Querier Query interval is 125 seconds Port Purge Interval is 260 seconds Max Response Code is 10000, Time is 10 seconds
