| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System ONET Administration Guide |
ONET works in tandem with SEFOS so that the one-to-one uplink to downlink port combination is achieved. SEFOS uses a different set of configuration files when used with ONET. ONET cannot run in conjunction with stand-alone SEFOS, and SEFOS must be stopped before ONET can be started. When ONET is started while SEFOS is running, Oracle ILOM displays the following message:
-> start /NEM/onet Are you sure you want to start /NEM/onet (y/n)? y start: ONET start failed because SEFOS is running
