| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System ONET Administration Guide |
Stopping SEFOS Before Starting ONET
show interfaces description Command
Oracle(R) Integrated Lights Out Manager (Fabric Component Edition) Version 3.0.5.2 Copyright (c) 2011, Oracle and/or its affiliates. All rights reserved. Warning: password is set to factory default. -> start /NEM/onet Are you sure you want to start /NEM/onet (y/n)? y start: Please wait while onet comes up, this can take anywhere from 30 seconds to 2 minutes depending on the configuration ...................... start: ONET Enabled successfully.
