Skip Navigation Links
Exit Print View
Oracle Ethernet Switches
L2 and L3 Deployment Best Practices
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Switches Overview
Oracle Switch ES1-24
Sun Network 10GbE Switch 72p
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 and L3 Topology
L2 and L3 VLAN Best Practices
Adding VLANs
Add an Untagged VLAN
Add a Tagged VLAN
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Example Overview
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 Implementations Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Verify the L3 OSPF Configuration
Glossary
Index
  1. Start the configuration with all ports and the default VLAN shutdown.
    Disable GVRP and GMRP.
    TOR72p-2 SEFOS# configure terminal
    TOR72p-2 SEFOS(config)# set gvrp disable
    TOR72p-2 SEFOS(config)# set gmrp disable
    TOR72p-2 SEFOS(config)# set port-channel enable
    TOR72p-2 SEFOS(config)# interface vlan 1
    TOR72p-2 SEFOS(config-if)# shutdown
    TOR72p-2 SEFOS(config-if)# no ip address
    TOR72p-2 SEFOS(config-if)# exit
    TOR72p-2 SEFOS(config)# interface range extreme-ethernet 0/1-72
    TOR72p-2 SEFOS(config-if-range)# shutdown
    TOR72p-2 SEFOS(config-if-range)# end
  2. Create and enable port-channels between switches per the topology.
    See L2 and L3 Topology.
    TOR72p-2 SEFOS(config)# interface port-channel 11
    TOR72p-2 SEFOS(config-if)# no shutdown
    TOR72p-2 SEFOS(config)# interface port-channel 13
    TOR72p-2 SEFOS(config)# interface port-channel 15
    TOR72p-2 SEFOS(config)# end
  3. Configure VLANs manually.
    You must add at least one port to the VLAN before you can assign the VLAN a name.
    TOR72p-2 SEFOS(config)# vlan 2002
    TOR72p-2 SEFOS(config-vlan)# ports add port-channel 11 untagged port-channel 10 name 192_168_202_0_RIP_P2P
    TOR72p-2 SEFOS(config-vlan)# vlan active
    TOR72p-2 SEFOS(config-vlan)# exit
    TOR72p-2 SEFOS(config)# vlan 2004
    TOR72p-2 SEFOS(config-vlan)# ports add port-channel 13 untagged port-channel 12 name 192_168_204_0_RIP_P2P
    TOR72p-2 SEFOS(config)# vlan 2006
    TOR72p-2 SEFOS(config-vlan)# ports add port-channel 15 untagged port-channel 14 name 192_168_206_0_RIP_P2P
    TOR72p-2 SEFOS(config)# vlan 30
    TOR72p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/66 untagged extreme-ethernet 0/66 name 192_168_40_0_HOST_P2P
    Note - You can add VLANs as tagged or untagged to a port or a port-channel in three different ways. See Adding VLANs.
  4. Configure the port-channels as access links by setting the pvid and adding port-channels to VLANs.
    Also, disable spanning-tree on all uplinks.
    TOR72p-2 SEFOS(config-if)# switchport pvid 2002
    TOR72p-2 SEFOS(config-if)# spanning-tree disable
    TOR72p-2 SEFOS(config-if)# switchport pvid 2004
    TOR72p-2 SEFOS(config-if)# switchport pvid 2006
  5. Enable the ports and add them to the appropriate port-channels.
    Configure the host port as an access link with a different VLAN.
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/66
    TOR72p-2 SEFOS(config-if)# description "connected to nxge1 Host-4"
    TOR72p-2 SEFOS(config-if)# switchport pvid 40
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/67
    TOR72p-2 SEFOS(config-if)# description "connected to ES1-24p-1 on port24"
    TOR72p-2 SEFOS(config-if)# channel-group 13 mode active
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/71
    TOR72p-2 SEFOS(config-if)# description "connected to ES1-24p-1 on port22"
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/68
    TOR72p-2 SEFOS(config-if)# description "connected to ES1-24p-2 on port24"
    TOR72p-2 SEFOS(config-if)# channel-group 15 mode active
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/72
    TOR72p-2 SEFOS(config-if)# description "connected to ES1-24p-2 on port22"
  6. Enable the uplink interfaces to the core switch and add them to the port-channel.
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/69
    TOR72p-2 SEFOS(config-if)# description "connected to Core switch on g1/2"
    TOR72p-2 SEFOS(config-if)# speed 1000
    TOR72p-2 SEFOS(config-if)# channel-group 11 mode active
    TOR72p-2 SEFOS(config)# interface extreme-ethernet 0/70
    TOR72p-2 SEFOS(config-if)# description "connected to Core switch on g1/3"
  7. Configure the L3 interface for all VLANs defined previously.
    TOR72p-2 SEFOS(config)# interface vlan 2002
    TOR72p-2 SEFOS(config-if)# ip address 192.168.202.10 255.255.255.0
    TOR72p-2 SEFOS(config)# interface vlan 2004
    TOR72p-2 SEFOS(config-if)# ip address 192.168.204.10 255.255.255.0
    TOR72p-2 SEFOS(config)# interface vlan 2006
    TOR72p-2 SEFOS(config-if)# ip address 192.168.206.10 255.255.255.0
    TOR72p-2 SEFOS(config)# interface vlan 40
    TOR72p-2 SEFOS(config-if)# ip address 192.168.40.10 255.255.255.0
  8. Enable RIP and advertise the networks that are reachable through this switch.
    TOR72p-2 SEFOS(config)# router rip
    TOR72p-2 SEFOS(config-router)# version 2
    TOR72p-2 SEFOS(config-router)# auto-summary disable
    TOR72p-2 SEFOS(config-router)# redistribute connected
    TOR72p-2 SEFOS(config-router)# network 192.168.202.10
    TOR72p-2 SEFOS(config-router)# network 192.168.204.10
    TOR72p-2 SEFOS(config-router)# network 192.168.206.10
    TOR72p-2 SEFOS(config-router)# network 192.168.40.10
    TOR72p-2 SEFOS(config-router)# end
  9. Enable the VLANs to send and receive RIP version 2 updates.
    TOR72p-2 SEFOS(config-if)# ip rip send version 2
    TOR72p-2 SEFOS(config-if)# ip rip receive version 2
    TOR72p-2 SEFOS(config-if)# end
  10. Save the configuration.
    TOR72p-2 SEFOS# copy run start
    Building configuration ...
    [OK]
  11. Verify the status of the interfaces.
    TOR72p-2 SEFOS# show interface description
    Interface    Status   Protocol  Description
    Ex0/1        down     down
    Ex0/63       down     down
    Ex0/64       down     down
    Ex0/65       down     down
    Ex0/66       up       up        connected to nxge1 Host-4
    Ex0/67       up       up        connected to ES1-24p-1 on port24
    Ex0/68       up       up        connected to ES1-24p-2 on port24
    Ex0/69       up       up        connected to Core switch on g1/2
    Ex0/70       up       up        connected to Core switch on g1/3
    Ex0/71       up       up        connected to ES1-24p-1 on port22
    Ex0/72       up       up        connected to ES1-24p-2 on port22
    po11         up       up
    po13         up       up
    po15         up       up
    vlan1        down     down
    vlan2002     up       up
    vlan2004     up       up
    vlan2006     up       up
    vlan40       up       up
  12. Verify the routes learned.
    ToR72p-2 SEFOS# show ip route
    Codes: C - connected, S - static, R - rip, B - bgp, O - ospf
    R 192.168.9.0/24 [2] via 192.168.202.20
    R 192.168.20.0/24 [2] via 192.168.202.20
    R 192.168.30.0/24 [3] via 192.168.202.20
    C 192.168.40.0/24 is directly connected, vlan40
    R 192.168.50.0/24 [4] via 192.168.202.20
    R 192.168.60.0/24 [4] via 192.168.202.20
    R 192.168.100.0/24 [4] via 192.168.202.20
    R 192.168.101.0/24 [4] via 192.168.202.20
    R 192.168.150.0/24 [2] via 192.168.202.20
    R 192.168.151.0/24 [2] via 192.168.202.20
    R 192.168.201.0/24 [2] via 192.168.202.20
    C 192.168.202.0/24 is directly connected, vlan2002
    R 192.168.203.0/24 [3] via 192.168.202.20
    C 192.168.204.0/24 is directly connected, vlan2004
    R 192.168.205.0/24 [3] via 192.168.202.20
    C 192.168.206.0/24 is directly connected, vlan2006
    R 45.45.45.0/24 [3] via 192.168.202.20
    R 45.45.46.0/24 [3] via 192.168.202.20
    R 45.45.47.0/24 [3] via 192.168.202.20
    R 45.45.48.0/24 [3] via 192.168.202.20
    R 45.45.49.0/24 [3] via 192.168.202.20
    R 45.45.50.0/24 [3] via 192.168.202.20
    R 45.45.51.0/24 [3] via 192.168.202.20
  13. Verify the number of routes.
    After IXIA sends 500 routes to the core switch, those routes are learned on this switch.
    TOR72p-2 SEFOS# show ip route summary
    Route Source    Routes
    connected         4
    static            0
    rip               512
    bgp               0
    ospf              0
    Total             516
Related Information
