Skip Navigation Links
Exit Print View
Oracle Ethernet Switches
L2 and L3 Deployment Best Practices
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Switches Overview
Oracle Switch ES1-24
Sun Network 10GbE Switch 72p
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 and L3 Topology
L2 and L3 VLAN Best Practices
Adding VLANs
Add an Untagged VLAN
Add a Tagged VLAN
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Example Overview
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 Implementations Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Verify the L3 OSPF Configuration
Glossary
Index
Note - All pings should be successful.
  1. Check the configuration on Host-6.
    Host-6 has a bond to test the Active/Standby configuration.
    [Host-6 ~]# ifconfig
    bond0     Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.99.25  Bcast:192.168.99.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link          UP BROADCAST RUNNING MASTER MULTICAST  MTU:1500  Metric:1          RX packets:73 errors:0 dropped:0 overruns:0 frame:0          TX packets:151 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:0           RX bytes:9490 (9.2 KiB)  TX bytes:18909 (18.4 KiB)
    bond0.200 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.20.25  Bcast:192.168.20.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.201 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.21.25  Bcast:192.168.21.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.202 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.22.25  Bcast:192.168.22.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.203 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.23.25  Bcast:192.168.23.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.300 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.30.25  Bcast:192.168.30.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.301 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.31.25  Bcast:192.168.31.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.302 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.32.25  Bcast:192.168.32.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    bond0.303 Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9            inet addr:192.168.33.25  Bcast:192.168.33.255  Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe22:fd9/64 Scope:Link
    eth1      Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9
    eth6      Link encap:Ethernet  HWaddr 00:10:E0:22:0F:D9
  2. Check the configuration on Host-2.
    [Host-2 ~]# ifconfig -a
    nxge1: flags=1001000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,FIXEDMTU> mtu 9000 index 4        inet 192.168.99.15 netmask ffffff00 broadcast 192.168.99.255        ether 0:14:4f:6c:43:9
    nxge200001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 6        inet 192.168.20.15 netmask ffffff00 broadcast 192.168.20.255        ether 0:14:4f:6c:43:9
    nxge201001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 7        inet 192.168.21.15 netmask ffffff00 broadcast 192.168.21.255        ether 0:14:4f:6c:43:9
    nxge202001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 8        inet 192.168.22.15 netmask ffffff00 broadcast 192.168.22.255        ether 0:14:4f:6c:43:9
    nxge203001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 9        inet 192.168.23.15 netmask ffffff00 broadcast 192.168.23.255        ether 0:14:4f:6c:43:9
    nxge300001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 10        inet 192.168.30.15 netmask ffffff00 broadcast 192.168.30.255        ether 0:14:4f:6c:43:9
    nxge301001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 11        inet 192.168.31.15 netmask ffffff00 broadcast 192.168.31.255        ether 0:14:4f:6c:43:9
    nxge302001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 12        inet 192.168.32.15 netmask ffffff00 broadcast 192.168.32.255        ether 0:14:4f:6c:43:9
    nxge303001: flags=201000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4,CoS> mtu 9194 index 13        inet 192.168.33.15 netmask ffffff00 broadcast 192.168.33.255        ether 0:14:4f:6c:43:9
  3. Check the configuration on Host-1.
    [Host-1 ~]# ifconfig
    eth3      Link encap:Ethernet  HWaddr 00:10:E0:1F:BD:E3            inet addr:192.168.99.10  Bcast:192.168.99.255
              Mask:255.255.255.0          inet6 addr: fe80::210:e0ff:fe1f:bde3/64 Scope:Link          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1          RX packets:734694172 errors:0 dropped:229967577 overruns:0
    frame:0          TX packets:408889295 errors:0 dropped:0 overruns:0
              carrier:0          collisions:0 txqueuelen:1000           RX bytes:48601478150 (45.2 GiB)  TX bytes:17173383292
              (15.9 GiB)
    eth3.300  Link encap:Ethernet  HWaddr 00:10:E0:1F:BD:E3            inet addr:192.168.30.10  Bcast:192.168.30.255
    eth3.301  Link encap:Ethernet  HWaddr 00:10:E0:1F:BD:E3            inet addr:192.168.31.10  Bcast:192.168.31.255
    eth3.302  Link encap:Ethernet  HWaddr 00:10:E0:1F:BD:E3            inet addr:192.168.32.10  Bcast:192.168.32.255
    eth3.303  Link encap:Ethernet  HWaddr 00:10:E0:1F:BD:E3          inet addr:192.168.33.10  Bcast:192.168.33.255
  4. Check the Active and Standby links of the bond on Host-6.
    [Host-6 ~]# cat /proc/net/bonding/bond0
    Ethernet Channel Bonding Driver: v3.6.0 (September 26, 2009)
    Bonding Mode: fault-tolerance (active-backup)Primary Slave: eth1 (primary_reselect always)Currently Active Slave: eth1MII Status: up
    MII Polling Interval (ms): 100Up Delay (ms): 0Down Delay (ms): 0
    Slave Interface: eth1MII Status: upLink Failure Count: 1
    Permanent HW addr: 00:10:e0:22:0f:d9Slave queue ID: 0
    Slave Interface: eth6MII Status: up
    Link Failure Count: 1Permanent HW addr: 00:10:e0:22:0f:da
    Slave queue ID: 0
  5. Ping from Host-6 to an untagged interface on Host-1, Host-2 of the core switch, and ToR72p-1.
    [Host-6 ~]# ping 192.168.99.10
  6. Ping from Host-6 to a tagged interface on Host-1, Host-2 of the core switch, and ToR72p-1.
    [Host-6 ~]# ping 192.168.33.10
    [Host-6 ~]# ping 192.168.30.10
  7. Ping from Host-1 and Host-2 to a tagged interface on Host-6 of ES1-24p-1.
    [Host-1 ~]# ping 192.168.33.25
    [Host-2 ~]# ping -s 192.168.20.25
Related Information
