Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide |
The following topology demonstrates the Uplink Port Trailing feature configured on access switches connecting to the servers. The example uses the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE at the access layer. To enable this feature, the interfaces connecting from the access switch to the Sun Ethernet 10GbE Switch 72 (ToR72) and server-facing interfaces are bound together in a group.
