Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide |
Sun Ethernet Fabric Operating System Uplink Port Trailing Protocol
[Host-1]# ifconfig -a eth4.300 Link encap:Ethernet HWaddr 90:E2:BA:79:83:94 inet addr:192.168.30.20 Bcast:192.168.30.255 Mask:255.255.255.0 inet6 addr: fe80::92e2:baff:fe79:8394/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:374 errors:0 dropped:0 overruns:0 frame:0 TX packets:377 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:30622 (29.9 KiB) TX bytes:35858 (35.0 KiB) eth4.301 Link encap:Ethernet HWaddr 90:E2:BA:79:83:94 inet addr:192.168.31.20 Bcast:192.168.31.255 Mask:255.255.255.0 inet6 addr: fe80::92e2:baff:fe79:8394/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:2 errors:0 dropped:0 overruns:0 frame:0 TX packets:6 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:92 (92.0 b) TX bytes:468 (468.0 b)
[Host-2]# cat /proc/net/bonding/bond0 Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) Bonding Mode: fault-tolerance (active-backup) Primary Slave: eth7 (primary_reselect always) Currently Active Slave: eth7 MII Status: up MII Polling Interval (ms): 100 Up Delay (ms): 0 Down Delay (ms): 0 Slave Interface: eth6 MII Status: up Speed: 10000 Mbps Duplex: full Link Failure Count: 5 Permanent HW addr: 00:1b:21:66:48:ec Slave queue ID: 0 Slave Interface: eth7 MII Status: up Speed: 10000 Mbps Duplex: full Link Failure Count: 11 Permanent HW addr: 00:1b:21:66:48:ed Slave queue ID: 0 [Host-2]# ifconfig -a bond0.300 Link encap:Ethernet HWaddr 00:1B:21:66:48:EC inet addr:192.168.30.50 Bcast:192.168.30.255 Mask:255.255.255.0 inet6 addr: fe80::21b:21ff:fe66:48ec/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:374 errors:0 dropped:0 overruns:0 frame:0 TX packets:536 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:30622 (29.9 KiB) TX bytes:45960 (44.8 KiB) bond0.301 Link encap:Ethernet HWaddr 00:1B:21:66:48:EC inet addr:192.168.31.50 Bcast:192.168.31.255 Mask:255.255.255.0 inet6 addr: fe80::21b:21ff:fe66:48ec/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:39 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 b) TX bytes:2646 (2.5 KiB) NEM24p-1 SEFOS# sh uplink-trailing group 20 detail Uplink Trailing Group 20 Description: Uplink-trailing between NEM24p-1 & ToR72p-1 Admin Status: Enabled Status: Up Link State Change: Up 1 Down 0 Port Type Status Ex0/1 uplink Up Ex0/18 downlink Up
