Oracle VM Server Installation Task Map
The following table describes the high-level steps for installing Oracle VM Server.
1.
Install the server hardware and configure the service processor.
2.
Review the Oracle VM Server versions supported on the server.
3.
Set up a second system with a static IP address on which you can install the Oracle VM Manager. This system must have one of the following operating systems installed:
Oracle Linux 5 Update 5, 64-bit or subsequent releases
Oracle Linux 6, 64-bit or subsequent releases
Red Hat Enterprise Linux 5 Update 5, 64-bit or subsequent releases
Red Hat Enterprise Linux 6, 64-bit or subsequent releases
4.
Obtain the Oracle VM Server installation media and the Oracle VM documentation. The Oracle VM documentation should be used in conjunction with the installation procedures in this guide.
5.
Review the server product notes.
6.
Set up the boot environment, console, boot media, and installation target that you will use to perform the installation.
7.
Install Oracle VM Server and, if necessary, Oracle VM Manager.
For procedures for installing both the Oracle VM Server and the Oracle VM Manager, see Installing Oracle VM.
8.
Perform the post installation tasks, if applicable.
