Installing the Server Into a Rack
This section describes how to install the server into a rack using the rail assembly in
the rackmount kit. Perform these procedures if you purchased the rail assembly.
Note -
In this guide, the term "rack" means either an open rack or a closed cabinet.
Complete all installation prerequisite tasks.
Check that your rack meets the requirements for installation of this
server.
Review safety precautions.
Verify that you have received all components in the rackmount
kit.
Stabilize the rack.
Install mounting brackets onto the server.
Mark the rackmount location.
Connect AC power cables in the Sun Rack II 1042.
Attach the tool-less slide-rail assembly to the rack.
Install the server into the slide-rail assembly.
(Optional) Install the cable management arm for routing server
cables.
