Attach Tool-less Slide-Rail Assemblies
Use this procedure to attach tool-less slide-rail assemblies to the rack.
Orient the slide-rail assembly so that the ball-bearing track is forward and
locked in place.
1
Slide-rail
2
Ball-bearing track
3
Locking mechanism
Starting with either the left or right side of the rack, align the rear of the
slide-rail assembly against the inside of the rear rack rail, and push until the
assembly locks into place with an audible click.
Align the front of the slide-rail assembly against the outside of the front
rack rail, and push until the assembly locks into place with an audible
click.
Repeat Step 1
through Step 3 to attach the
slide-rail assembly to the other side of the rack.
