Go to main content
Oracle® Server X5-2L Installation Guide
Exit Print View
Updated: January 2021
Oracle VM Server Configuration Worksheet
Before you begin configuring the preinstalled Oracle VM Server, use the worksheet in this section to gather the information you will need.
Table 11  Worksheet for Oracle VM Server Configuration
Information for Configuration
Description and Example
Your Answers
Oracle VM Server passwords
Root
Choose a root password; there are no restrictions on the characters or length.
Oracle VM agent
Choose an Oracle VM agent password; password must be at least six characters.
Network interface
Supply the interface to be used to manage the server.
Network configuration
Static IP address
Supply the IP address for the server. A static IP address is required.
Example: 198.51.100.1
Netmask
If the server is part of a subnet, supply the netmask of the subnet.
Example: 10.255.255.0
Gateway
If the server is accessed via a gateway, supply the IP address of the gateway.
DNS server
Supply the IP address for the domain name server (DNS). Only one DNS is required.
Host name
Supply the fully qualified domain name for the server.
Example: myhost.hs.example.com
