Go to main content
Oracle® Server X5-2L Installation Guide
Exit Print View
Updated: January 2021
Download Firmware and Software Updates From My Oracle Support
  1. Go to the My Oracle Support web site: https://support.oracle.com.
  2. Sign in to My Oracle Support.
  3. At the top of the page, click the Patches & Updates tab.
    The Patch Search pane appears at the right of the screen.
  4. Within the Search tab area, click Product or Family (Advanced).
    The Search tab area appears with search fields.
  5. In the Product field, select the product from the drop-down list.
    Alternatively, type a full or partial product name (for example, Oracle Server X5-2L) until a match appears.
  6. In the Release field, select a software release from the drop-down list.
    Expand the list to see all available software releases.
  7. Click Search.
    The Patch Advanced Search Results screen appears, listing the patches for the software release.
    See Software Releases for a description of the available software releases.
  8. To select a patch for a software release, click the patch number next to the software release version.
    You can use the Shift key to select more than one patch.
    A pop-up action panel appears. The panel contains several action options, including the ReadMe, Download, and Add to Plan options. For information about the Add to Plan option, click the associated button and select “Why use a plan?”.
  9. To review the ReadMe file for this patch, click ReadMe.
  10. To download the patch for the software release, click Download.
  11. In the File Download dialog box, click the patch zip file name.
    The patch for the software release downloads.
