Software Releases
Software releases on My Oracle Support are grouped by product family (such
as Oracle Server), then the product (the specific server or blade),
and finally the software release version. A software release contains
all the updated software and firmware for your server or blade as a
set of downloadable files (patches), including firmware, drivers,
tools, or utilities, all tested together to be compatible with your
server.
Each patch is a zip file that contains a ReadMe file and a set of
subdirectories containing firmware or software files. The ReadMe file
contains details on the components that have changed since the prior
software release and the bugs that have been fixed.
My Oracle Support provides the set of software releases for your server as
described in the following table. You can obtain these software
releases by downloading the files from My Oracle Support.
Alternatively, you can download the same firmware and software to your
server using Oracle System Assistant.
Table 12 Software Release Packages
X5-2L SW
release –
Firmware Pack
Contains all system firmware, including
Oracle ILOM, BIOS, and option card
firmware.
You need the latest firmware.
X5-2L SW
release – OS
Pack
Includes a package of all tools, drivers,
and utilities for a specific OS. An OS Pack is
available for each supported operating system
version.
Software includes Oracle Hardware Management
Pack, LSI MegaRAID software, and any other
optional software that Oracle recommends.
For the Windows OS, the OS Pack also
includes Intel Network Teaming and Install
Pack.
You need to update OS-specific tools,
drivers, or utilities.
X5-2L SW
release – All
Packs
Includes the Firmware Pack, all OS Packs,
and all documents.
This pack does not include Oracle VTS or the
Oracle System Assistant image.
You need to update a combination of system
firmware and OS-specific software.
X5-2L SW
release –
Diagnostics
Includes Oracle VTS diagnostics
image.
You need the Oracle VTS diagnostics
image.
X5-2L SW
release – Oracle System
Assistant Updater
Includes Oracle System Assistant
recovery/update ISO image.
You need to manually recover or update
