Rackmount Checklist
Complete the following checklist prior to installing the server
into a rack or cabinet.
Table 16 Rackmount Checklist
Is the distance between the front and rear mounting planes between the minimum of 610 mm and
the maximum 915 mm (24 inches to 36 inches)? |
Is the clearance depth in the front of the front mounting plane (distance to the front cabinet
door) at least 25.4 mm (1 inch)? |
Does the target
rack meet the following minimum load capacity?
Is the rack
a four-post rack (mounting at both front and rear)?
Two-post racks are not compatible. |
Does the rack's
horizontal opening and unit vertical pitch conform to ANSI/EIA 310-D-1992 or
IEC 60927 standards? |
Does the rack
have RETMA rail support? |
Does the rack
support Oracle cable management arms (CMAs)? |
Does the rack
support installation of Oracle vented and solid filler panels? |
Can the rack
provide tie-downs for the Ethernet wiring harness? |
Is there sufficient
space for the cable harnesses and the power distribution units (PDUs) in
the rack? |
Can a label
with the serial number be printed and attached to the target rack? |
Does the rack
support installation of standard Oracle PDUs?
If not, then complete this checklist. |
Can the customer
provide an equivalent pair of PDUs? |
Can the customer
provide two PDUs with capacity of 110kVA per PDU? |
Can the customer
provide a single PDU and its circuits to support the power requirements
in case one PDU fails? |
Can the customer
ensure power loads are evenly distributed across all circuits of
a single PDU? |
Can the customer provide
appropriate power drops for the PDUs? |
