Go to main content
Oracle® Server X5-2L Installation Guide
Exit Print View
Updated: January 2021
Optional Component Installation
Standard system components are installed at the factory. Optional components that you purchased independent of the standard configuration are shipped separately, and in most cases should be installed before you install the server in a rack.
The following optional components can be ordered and purchased separately:
  • PCIe cards
  • DDR4 DIMM memory kits
  • Storage drives
  • Shipping bracket
  • Software media
If you ordered any options that are field-replaceable units (FRUs) or customer-replaceable units (CRUs), refer to the service label on the top cover of the server or the component removal and replacement procedures in the Oracle Server X5-2L Service Manual for installation instructions.
Supported components and their part numbers are subject to change over time and without notice. For the most up-to-date list, review the Oracle System Handbook at:
https://support.oracle.com/handbook_private/Systems/index.html
You can also log in to My Oracle Support to access the Oracle System Handbook. To access the handbook, log in to My Oracle Support. Select the Knowledge tab, and then select Oracle System Handbook. Within the handbook, click Systems, and then click the name and model of your server. On the product page that opens for the server, click Full Components List for a list of components.
Note -  You must have an Oracle Service contract to access the Oracle System Handbook.
Related Information
