Logistics Checklist
Complete the following checklist to ensure that the logistics
requirements are met for the data center in which the server will
be installed.
Table 19 Logistics Checklist
Do you have contact information for the data center personnel? |
Is there security or access control for the data center? |
Are there any
security background checks or security clearances required for vendor personnel
to access the data center? If yes, then do you have a recommended
agency? |
How many days
in advance must background checks be completed? |
Are there any
additional security access issues? |
Is computer
room access available for installation personnel? |
Are laptops,
cell phones, and cameras allowed in the data center? |
Does the building
have a delivery dock? |
Is there a
delivery/unpacking/staging area? |
Is the delivery
inside? |
If the delivery
is not inside, then is the site prepared for uncrating? |
Is the unpacking/staging
area protected from the elements? |
Does the building
have adequate receiving space? |
Is the unpacking
area air-conditioned to avoid thermal shock for various hardware components? |
Will sufficient
moving personnel be available to install the hardware? |
Are you prepared
for uncrating and trash removal? |
Are there any
restrictions on delivery and trash removal? |
Are there any
restrictions on delivery truck length, width or height? |
Does the customer
allow cardboard boxes and other packing material in the computer
room? |
Is there a
time constraint on dock access? If yes, then provide time constraints. |
Is tail lift required on
delivery carrier to unload the equipment at the delivery dock? |
