Oracle System Assistant enables you to set up and manage the Oracle Server X5-2L. Oracle System Assistant is a task-based server provisioning tool that helps you to perform initial server setup and maintenance for Oracle x86 servers. Using Oracle System Assistant, you can install a supported Oracle Solaris, Oracle VM, Linux, or Windows operating system, update your server to the latest software release, and configure server hardware. Oracle System Assistant is a factory-installed option that is available when you purchase the server. If your server includes Oracle System Assistant, it resides on an internal USB flash drive.
For information about using Oracle System Assistant, see the Oracle X5 Series Servers Administration Guide at https://www.oracle.com/goto/x86admindiag/docs.
