Server Physical Specifications
The following table lists the physical specifications for the Oracle Server
X5-2L.
Table 1 Oracle Server X5-2L Physical Specifications
Width
Server chassis
44.5 cm (17.5 inches)
Depth
Maximum overall
73.7 cm (29 inches)
Height
2-rack unit (2U) nominal
8.76 cm (3.45 inches)
Weight
Fully populated server
8-Disk Configuration
12-Disk Configuration
24-Disk Configuration
24.494 kg (54 lbs)
29.937 kg (66 lbs)
29.030 kg (64 lbs)
