Go to main content
Oracle® Server X5-2L Installation Guide
Exit Print View
Updated: January 2021
Receiving and Unpacking Guidelines
The following table lists the dimensions and weights for the shipping cartons that contain the Oracle Server X5-2L.
Table 3  Shipping Carton Specifications
Requirement
Specification
Shipping carton height
30.5 cm (12 inches)
Shipping carton width
59.9 cm (23.6 inches)
Shipping carton length
98.4 cm (38.7 inches)
Shipping carton weight
5.8 kg (12.8 lbs)
When the Oracle Server X5-2L is unloaded at your site, leave the server in its shipping carton until it arrives in its installation location. Use a separate area in which to remove the packaging material to reduce particle contamination before entering the data center. Ensure that there is enough clearance and clear pathways for moving the Oracle Server X5-2L from the unpacking area to the installation location.
