Go to main content
Oracle® Server X5-2L Installation Guide
Exit Print View
Updated: January 2021
Humidity Guidelines
The ambient relative humidity range of 45 to 50 percent is suitable for safe data processing operations. Most computer equipment can operate in a wide range (20 to 80 percent), but the range of 45 to 50 percent is recommended for the following reasons:
  • Optimal range helps protect computer systems from corrosion problems associated with high humidity levels.
  • Optimal range provides the greatest operating time buffer in the event of air conditioner control failure.
  • This range helps to avoid failures or temporary malfunctions caused by intermittent interference from static discharges that may occur when relative humidity is too low. Electrostatic discharge (ESD) is easily generated and less easily dissipated in areas where the relative humidity level is below 35 percent. ESD risk becomes critical when levels drop below 30 percent.
