Install the Cable Management Arm
Follow this procedure to install the cable management arm (CMA), which you can use
to manage cables connected to the rear of the server.
Unpack the CMA.
The following figure shows the CMA components.
1
Connector A
2
Front slide bar
3
Velcro straps (6)
4
Connector B
5
Connector C
6
Connector D
7
Slide-rail latching bracket (used with connector D)
8
Rear slide bar
9
Oracle Server X5-2L cable covers
10
Oracle Server X5-2LL cable covers
Ensure that the correct cable covers for your server are installed on the
CMA.
Note -
The CMA ships with three, flat cable covers installed. If you are going to
install the CMA on a Oracle Server X5-2L, you need to remove the flat cable covers
and install the round cable covers.
If you are installing the CMA on a Oracle Server X5-2L, remove the flat cable
covers and install the round cable covers; otherwise proceed to the next
step.
To remove the flat cable covers and install the round cable covers, perform
these steps:
Lift up on the cable cover handle (the handle is colored green) and
open it 180 degrees to the horizontal position as shown in the following
figure [frames 1 and 2].
Note -
The CMA has three cable covers, two with two hinges (one of which
is shown the following figure), and one with a single hinge. All
three cable covers are shown in the figure in
Step 1.
Apply upward pressure to the outside edge of each hinge connector
until the hinge connector comes off the hinge [frame 3].
Repeat Step 3.a and Step 3.b to remove all three cable covers.
One at a time, position each round cable cover horizontally over the
hinges, and align the hinge connectors with the hinges.
Using your thumb, apply downward pressure on each hinge connector to
snap the hinge connector into place.
Swing the cable covers down and press down on the cable cover handle
to lock them into the closed position.
Ensure that the six Velcro straps are threaded into the CMA as shown in the
figure in Step 1.
Note -
Ensure that the two Velcro straps located on the front slide bar are
threaded through the opening in the top of the slide bar as shown in the
figure in
Step 1. This prevents
the Velcro straps from interfering with the expansion and contraction of the
slide bar when the server is extended out of the rack and returned into the
rack.
To make it easier to install the CMA, extend the server approximately 13 cm (5
inches) out of the front of the rack.
Take the CMA to the back of the equipment rack, and ensure that you have
adequate room to work at the back of the server.
Note -
References to “left” or “right” in this procedure
assume that you are facing the back of the equipment rack.
Note -
Throughout this installation procedure, support the CMA and do not allow
it to hang under its own weight until it is secured at all four attachment
points.
To install the CMA's connector A into the right slide-rail:
Insert the CMA's connector A into the front slot on the left
slide-rail until it locks into place with an audible click [frames 1 and
2].
The connector A tab (see callout 1) goes into the slide-rail's front
slot (callout 2).
Gently tug on the right side of the front slide bar to verify that
connector A is properly seated.
1
Connector A tab
2
Left slide-rail front slot
To install the CMA's connector B into the right slide-rail:
Insert the CMA's connector B into the front slot on the right
2].
The connector B tab (see callout 1) goes into the slide-rail's front
slot (callout 2).
connector B is properly seated.
1
Connector B tab
2
Right slide-rail front slot
To install the CMA's connector C into the right slide-rail:
Align connector C with the slide-rail so that the locking spring
(callout 1) is positioned inside (server side) of the right slide-rail
[frame 1].
1
Connector C locking spring
Insert connector C into the right slide-rail until it locks into place
with an audible click [frames 2 and 3].
Gently tug on the right side of the CMA's rear slide bar to verify
that connector C is properly seated.
To prepare the CMA's connector D for installation, remove the tape that
secures the slide-rail latching bracket to connector D and ensure that the
latching bracket is properly aligned with connector D [frames 1 and 2].
Note -
The CMA is shipped with the slide-rail latching bracket taped to connector
D. You must remove the tape before you install this connector.
To install the CMA's connector D into the left slide-rail:
While holding the slide-rail latching bracket in place, insert
connector D and its associated slide-rail latching bracket into the left
slide-rail until connector D locks into place with an audible click
[frames 1 and 2].
Note -
When inserting connector D into the slide-rail, the preferred and
easier method is to install connector D and the latching bracket as
one assembly into the slide-rail.
Gently tug on the left side of the CMA's slide bar to verify that
connector D is properly seated.
Note -
The slide-rail latching bracket has a green release tab. This tab
is used to release and remove the latching bracket so that you can
remove connector D.
Gently tug on the four CMA connection points to ensure that the CMA connectors
are fully seated before you allow the CMA to hang by its own weight.
To verify that the slide-rails and the CMA are operating properly before
routing cables through the CMA:
Extend all rack anti-tilt devices to prevent the rack from
tipping forward when the server is extended.
 | Caution -
To reduce the risk of personal injury, stabilize the rack cabinet
and extend all anti-tilt devices before extending the server from
the rack.
For instructions for stabilizing the rack, see Stabilize the Rack for Installation.
Extend the server from the front of the rack until the CMA is fully
extended.
To return the server to the rack:
Simultaneously pull and hold the two green release tabs (one on each
side of the server) toward the front of the server while you push the
server into the rack. As you push the server into the rack, verify that
the CMA retracts without binding.
Note -
To pull the green release tabs, place your finger in the center of
each tab, not on the end, and apply pressure as you pull the tab
toward the front of the server.
Continue pushing the server into the rack until the slide-rail locks
(on the front of the server) engage the slide-rail assemblies.
You will hear an audible click when the server is in the normal rack
position.
Connect cables to the server, as required.
Instructions for connecting the server cables are provided in Cabling the Server and Applying Power.
Open the CMA cable covers, route server cables through the CMA's cable
troughs, close the cable covers, and secure the cables with the six Velcro
straps.
Route the cables through the cable troughs in this order:
First through the front-most cable trough
Then through the small cable trough
Then through the rear-most cable trough
Note -
When securing the cables with the Velcro straps located on the
front slide bar, ensure that the Velcro straps do not wrap around
the bottom of the slide bar; otherwise, expansion and contraction of
the slide bar might be hindered when the server is extended from the
rack and returned to the rack.
Ensure that the secured cables do not extend above the top or below the bottom
of the server to which they are attached; otherwise, the cables might snag on
other equipment installed in the rack when the server is extended from the rack
or returned to the rack.
Note -
If necessary, bundle the cables with additional Velcro straps to ensure
that they stay clear of other equipment. If you need to install additional
Velcro straps, wrap the straps around the cables only, not around any of the
CMA components; otherwise, expansion and contraction of the CMA slide bars
might be hindered when the server is extended from the rack and returned to
the rack.
