Supplemental
Software Component Options
Oracle System Assistant makes
several Supplemental
Software components available for the server. You have two options
for installation:
The following table identifies the optional Supplemental Software
components that Oracle System Assistant makes available for your
server.
Table 2 Optional Supplemental Software
Emulex OneInstall for Windows Servers
Emulex OneInstall installs all Emulex drivers (FC, FCoE, NIC, iSCSI, and Command Manager)
using a wizard.
Typical
Oracle Hardware Management Pack
provides tools to help you manage and configure your server. It enables you to:
Use a management agent at the operating system level to enable in-band monitoring of your
server hardware over Simple Network Management Protocol (SNMP). You can use this information to
integrate your server into your data center management infrastructure.
Use a management agent to enable in-band monitoring of your server's storage devices,
including RAID arrays. You can view this information from the Oracle Integrated Lights Out Manager
(ILOM) web interface or command-line interface (CLI).
Use a BIOS configuration tool, which runs on the host operating system and configures the host
BIOS CMOS settings, host boot order, and some service processor (SP) settings.
Use IPMItool to access the server's service processor via the IPMI protocol and perform
management tasks.
Typical
Intel Network Connections PROSet for Windows
Enables additional network features, including NIC Teaming.
Typical
LSI MegaRAID StorCLI
Enables you to configure, monitor, and maintain
RAID on the SAS 3 internal RAID host bus adapter (HBA).
Typical
LSI MegaRAID Storage Manager for Windows
Typical
Intel Chipset Software Installation Utility
Automatically tells you if you need to update your chipset INF files and prompts you to
install the files.
Typical
