Rackmount Kit Contents
The rackmount kit contains two slide-rails, two mounting brackets, and optional securing
screws.
Note -
Refer to the rackmount kit installation card for simplified instructions about
installing your storage server into a four-post rack, using the slide-rail and cable
management arm options.
1
Slide-rails
2
Mounting brackets
3
Four M4 x 5 fine-pitch mounting bracket securing screws (not used)
4
Installation card
