Go to main content
oracle home
Oracle
Server X5-2 Installation Guide for Linux Operating Systems
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Server X5-2 Documentation Library
Oracle
Server X5-2 ...
Configuring Network Interfaces
Updated: October 2016
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
About Linux Operating System Installs
Supported Linux Operating Systems
Oracle Unbreakable Enterprise Kernel for Linux
Selecting the Console Display Option
Console Display Options
Set Up the Local Console
Set Up the Remote Console
Selecting the Boot Media Option
Boot Media Options Requirements
Local Boot Media Requirements
Remote Boot Media Requirements
Set Up the Boot Media for a Local Installation
Set Up the Boot Media for a Remote Installation
Selecting the Installation Target Option
Installation Target Options
Important: Internal, USB Embedded Oracle System Assistant Flash Drive Should Not Be Used as a Boot or Storage Drive
Set Up a Local Storage Drive (HDD or SSD) as the Installation Target
Set Up a Fibre Channel Storage Area Network Device as the Installation Target
Linux OS Installation Options
Single-Server Installation Methods
Assisted Linux OS Installation
Manual Linux OS Installation
Oracle System Assistant Overview
Get Updates and Install OS Tasks
Obtaining Oracle System Assistant
Preparing to Install a Linux Operating System
Preparing the Boot Environment
Verify the UEFI Optimal Defaults
Set the Boot Mode
Configuring RAID
Installing a Linux Operating System
Installing a Linux OS on a Single System Using Oracle System Assistant
Install a Linux OS Using Oracle System Assistant
Installing Oracle Linux on a Single System Manually
Oracle Linux 6.5, 6.6, or 7 OS Installation Task Map
Before You Begin
Install Oracle Linux 6.5 or 6.6 OS Manually Using Local or Remote Media
Install Oracle Linux 7 OS Manually Using Local or Remote Media
Install Oracle Linux 6.5, 6.6, or 7 Using PXE Network Boot
Post Installation Tasks for Oracle Linux 6.5, 6.6, or 7 OS
Installing Red Hat Enterprise Linux OS on a Single System Manually
RHEL 6.5, 6.6, or 7 OS Installation Task Map
Before You Begin
Install RHEL 6.5, 6.6, or 7 OS Manually Using Local or Remote Media
Install RHEL 6.5, 6.6, or 7 Using PXE Network Boot
Post Installation Tasks for RHEL 6.5, 6.6, or 7 OS
Register RHEL and Activate Automatic Updates
Download and Install OS Updates
(Optional) Install Oracle Unbreakable Enterprise Kernel for Linux on RHEL Using Local or Remote Console
Installing SUSE Linux Enterprise Server OS on a Single System Manually
SLES OS Installation Task Map
Before You Begin
Install SLES 11 SP3 OS Manually Using Local or Remote Media
Install SLES 12 OS Manually Using Local or Remote Media
Install SLES OS Using PXE Network Boot
Post Installation Tasks for SLES OS
Update the SLES Operating System
NIC Connectors
Index
Index A
Index B
Index C
Index D
Index I
Index K
Index L
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Language:
English
This section contains information about:
NIC Connectors
Previous
Next
