Accessing Oracle SuperCluster M6-32 Security Resources
Security Information for SuperCluster Components
Understanding Oracle SuperCluster M6-32 Security Guidelines
Understanding Hardware Security Guidelines
Network Security Considerations
Understanding Oracle SuperCluster M6-32 Security Settings and Services
Changing Passwords on Default User Accounts
Change Passwords on Default Accounts
Default User Accounts and Passwords
Change the Exadata Storage Server Passwords
Change the Ethernet Switch Password
Default TCP/IP Ports and Services
Keeping Oracle SuperCluster M6-32 Secure
Managing SuperCluster Security
Oracle ILOM for Secure Management
Oracle Identity Management Suite
Oracle Enterprise Manager Ops Center (Optional)
Workload Monitoring and Auditing
Database Activity Monitoring and Auditing
Hard drives and solid state drives are often used to store sensitive information. To protect this information from unauthorized disclosure, sanitize drives prior to reusing, decommissioning, or disposing them.
Use disk-wiping tools such as the Oracle Solaris format(1M) command to completely erase all data from the drive.
Organizations should refer to their data protection policies to determine the most appropriate method to sanitize hard drives.
If required, take advantage of Oracle's Customer Data and Device Retention Service. Refer to this document: http://www.oracle.com/us/support/library/data-retention-ds-405152.pdf
![]() | Caution - Disk-wiping software might not be able to delete some data on modern drives, due to the way that they manage data access. |
