Accessing Oracle SuperCluster M6-32 Security Resources
Security Information for SuperCluster Components
Understanding Oracle SuperCluster M6-32 Security Guidelines
Understanding Hardware Security Guidelines
Network Security Considerations
Understanding Oracle SuperCluster M6-32 Security Settings and Services
Changing Passwords on Default User Accounts
Change Passwords on Default Accounts
Default User Accounts and Passwords
Change the Exadata Storage Server Passwords
Change the Ethernet Switch Password
Default TCP/IP Ports and Services
Keeping Oracle SuperCluster M6-32 Secure
Managing SuperCluster Security
Oracle ILOM for Secure Management
Oracle Identity Management Suite
Oracle Enterprise Manager Ops Center (Optional)
Workload Monitoring and Auditing
Oracle SuperCluster M6-32 updates are provided in QFSDP. Installing the QFSDP updates all components at the same time. This practice ensures that all components continue to run on a combination of software versions that have been fully tested together by Oracle.
Obtain the latest QFSDP from My Oracle Support at: http://support.oracle.com
For details about the supported software and firmware, refer to the Oracle SuperCluster M6-32 Product Notes. This document is available on the first compute node in this directory: /opt/oracle/node/doc/E41531_01/index.html
Note - Only Upgrade, update, or patch individual components in isolation for reactive maintenance under the advice of Oracle support.
