Accessing Oracle SuperCluster M6-32 Security Resources
Security Information for SuperCluster Components
Understanding Oracle SuperCluster M6-32 Security Guidelines
Understanding Hardware Security Guidelines
Network Security Considerations
Understanding Oracle SuperCluster M6-32 Security Settings and Services
Changing Passwords on Default User Accounts
Change Passwords on Default Accounts
Default User Accounts and Passwords
Change the Exadata Storage Server Passwords
Change the Ethernet Switch Password
Default TCP/IP Ports and Services
Keeping Oracle SuperCluster M6-32 Secure
Managing SuperCluster Security
Oracle ILOM for Secure Management
Oracle Identity Management Suite
Workload Monitoring and Auditing
Database Activity Monitoring and Auditing
Oracle Enterprise Manager Ops Center is an optional technology that you can use to manage some security aspects of Oracle SuperCluster M6-32.
Part of the Oracle Enterprise Manager suite, Oracle Enterprise Manager Ops Center is a converged hardware management solution that provides a single administrative interface for servers, OSs, firmware, virtual machines, zones, storage, and network fabrics. Oracle Enterprise Manager Ops Center is installed by default on Oracle SuperClusterM6-32.
You can use Oracle Enterprise Manager Ops Center to assign administrative access to collections of physical and virtual systems, monitor administrator activity, detect faults, and configure and manage alerts. Oracle Enterprise Manager Ops Center supports a variety of reports that enable you to compare systems against known configuration baselines, patch levels, and security vulnerabilities.
For more information, refer to the Oracle Enterprise Manager Ops Center documentation at: http://docs.oracle.com/cd/E27363_01/index.htm
Note - For previous versions of Oracle Enterprise Manager Ops Center, the Ops Center software was installed and run from the SuperCluster system. Beginning with the Oracle Enterprise Manager Ops Center 12c Release 2 (12.2.0.0.0) release, the Ops Center software must be installed and run on a system outside of the SuperCluster system.
