PreviousNextJavaScript must be enabled to correctly display this content
Square Hole Rack Installation
This section explains how to mount the Acme Packet 6300/6350’s mounting slide rail assembly in a square hole equipment rack. You can use 10-32 cage nuts as an alternative to the provided nut bars, but they must be mounted prior to this procedure.
