PreviousNextJavaScript must be enabled to correctly display this content
Rear-Mounting a Tapped Hole Rack Installation
To install the stationary slide rails on the rear of a
tapped hole equipment rack:
Locate the
following components:
4 x 10-32 x 5/8” screws
Expand and line up
the opposite end of the stationary slide rail on the outside of the rear rack
slide rail at the same height used for the front mount point.
Rear Mount Point
Place one 10-32
screw through the stationary slide rail ear and screw in place.
