Configuration - Features (cf_features with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Features will display the Features that have been configured for your Property under the Preference Group of Features.
Features are configured in Configuration>Profile>Preferences>Preferences for the Preference Group of Room_Feature.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
