Configuration - Folio Grouping Codes (cf_folio_groupings with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Folio Groupings will display the transaction codes associated with the Folio Groupings of Arrangement, Expense and Group Codes. The ability to configure transaction codes with Arrangement Groups is based on the activation of the Function ‘FOLIO ARRANGEMENTS’.
Folio Groupings are configured in System Configuration>Cashiering>Folio Groupings>Arrangement, Expense or Group.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
