Configuration - Origin Codes (cf_origincodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Origin Codes will display all Origin Codes that have been configured. Origin Codes are not property specific. Origin codes can be assigned to Reservations and on a Block Header.
Origin Codes are configured in System Configuration>Reservations>Codes>Origin Codes.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
