Configuration - Master Codes (cf_mastercodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Master Codes will display all Master Codes that have been configured in the application. Master codes are found throughout the configuration application and can also be created manually by the property. If the license code for multi property functionality is activated (OPP_MHOT), this report will represent all codes on the template form.
Master Codes are configured manually in System Configuration>Setup>Screen Design>List of Values Maintenance>LOV Group Maintenance and LOV Value Maintenance.
Entity Group.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
