Configuration - Profile Changes (cf_profilechanges with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration report Profile Changes will display all changes made to profiles for the date range specified. This information is pulled from the User Activity Log.
From Date. Manually enter, or select the calendar button, for the beginning date of the report data.
To Date. Manually enter, or select the calendar button, for the ending date of the report data.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
