Configuration - Rate Seasons (cf_rateseason with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration Report for Rate Seasons will display all Seasons that have been configured for the property.
Note: When the OPR <version number> ORS license code is active, the Select Property screen appears prior to the Report Parameters screen. Choose the property you want to view and select the OK button. The Report Parameters screen appears.
When the OPP <version number> PMS license code is active, Season Codes are configured in PMS in Configuration>Rate Management>Codes>Season Codes.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
