Configuration - Reason Codes (cf_reasoncodes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Portrait page orientation.
The Configuration report for Reason Codes will display all Adjustment Codes that have been configured in the application for your property.
Adjustment Codes are configured in Configuration>Cashiering>Adjustment Codes.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
