Configuration - Room Types (cf_roomtypes with GENREPPAR.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Configuration report for Room Types will display all Room Types and corresponding information that has been configured in the application.
Room Types are configured in Configuration>Reservations>Room Types.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
