Package Allowance Guests In House (finpkgallow with GEN1.FMX)
Note: When printing this Report help topic, we recommend printing with Landscape page orientation.
The Package Allowance Report displays all guests who have an attached package that has been configured with an allowance. The Allowance and Consumed columns will display the cumulative amounts for the reservation's entire stay.
Note: Prices and allowances displayed for packages will be the price and allowance from the configuration of the package when it was attached to the reservation. Since the package price and allowance is stored at the reservation level, package prices and allowances can be different from reservation to reservation and from within the Package configuration to the reservation.
Date. Manually enter, or select using the calendar button, the stay date to run the report for, including past dates. Therefore, the report will return all reservations with a package allowance which have a stay date equal to the one entered in this field. This date is not the date for which the allowance was created. The report output will display the cumulative allowance for that reservation, thus far, and the cumulative consumption of the package allowance.
Note: If a report is needed where a day by day breakdown of allowances needs to be displayed, Effective Package Allowance - TB (effpkgallowance_tb.rep) report will be helpful to use.
Package. Multi Select LOV to filter by specific packages.
Order By. Alphabetical, Room No.
Preview. Select to preview the report in a PDF format.
Print. Select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report.
