Folio Tax - Style 01 (foliotax_01 with FOL1.FMX)
Note: We recommend printing this help topic with Landscape page orientation.
This report was developed to meet reporting requirements for properties located in Spain to display the breakdown of VAT Tax that was posted on each reservation for a specified date range.
The report will NOT refer to the Cashiering>Reports Tax Buckets application setting. If there are net/ tax amounts in all the 20 buckets then report will include all the 1-20 tax and net buckets irrespective of what is selected in the setting. It will not include the net / tax groups for which values do not exist.
From Date. Manually enter, or select the Calendar button to choose, the beginning date for the date range used in the results of the report.
To Date. Manually enter, or select the Calendar button to choose, the ending date for the date range used in the results of the report.
Sort Order. Chronological, Folio No., Room.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report
