Folio Tax Revenue (foliotax_revenue with FOL2.FMX)
Note: We recommend printing this help topic with Landscape page orientation.
Use this report to display the total of all charges posted to a guest on a particular date. If charges were routed and paid for by another guest, the other guest’s total will reflect these charges. You have the ability to include each individual bill amount, or simply the total charged.
From Date. Manually enter, or select the Calendar button to choose, the beginning date for the date range used in the results of the report.
To Date. Manually enter, or select the Calendar button to choose, the ending date for the date range used in the results of the report.
Minimum Revenue. Enter the minimum amount of total revenue charged.
Include Bill Amounts. If checked, the output displays each bill number and the corresponding amount that will equal to the total charges for that guest.
Country. Select to filter on a particular country that is attached to a profile. You can select All Countries or one particular country.
Include Null Values. Display those guests whose total charges are zero. This would occur on an adjusted folio.
Sort Order. Alphabetical, Identification Number.
Note: When the Passport/ID Number View permission is not granted to the user, then the Passport/ID Number will be masked with X's except for the last two numbers.
Preview. Select to preview the report in a PDF format.
Print. select to print the report.
File. Select to save the report as a file.
Close. Select to exit the specific report
